Just joined, glad to be a member and Hello to all. I do need help with a part number for a wiring harness. The Yamaha engine is a 2008 115 LTR with tach. #6Y7-83540-80-00 and trim #6Y7-83670-40-00, I need a wire harness that will mate the engine to the gauges. Plug and play, if not, will cut and crimp connectors. Thanks for any help.
tach. and trim
The trim harness is 16ft p/n 6R3-82553-50-00, The Guage harness is 6Y5-53553-N0-00.
That harness plugs into the off white colored square connector on engine(usually by the 10 pin main harness connector) and plugs into square connector on Yamaha tach, the trim gauge pink wire connects to tach harness.
