The boat when purchased had a non working speedometer. 1999 115 Yamaha.
Purchsed 6Y5-83570-S5 new, to replace an older one which was not regestering correctly. First off replaced the old sending unit in the tank. No change.
The old guage had eight wires, plus two wires which came from another opening on the back. The 8 colors on the old meter is white, 2-blk, 1-yellow, 1 red, 1-gray, 1-white w/blue stripe, 1-green. the two from the other opening is 1-blue, 1-blk.
The new has 1-white, 1-yellow, 1-red, 2-black, 1-blue.
It seemed straight forward, white to pink wire from sending unit, yellow to yellow,red to red, 2-black to 2-black, but the blue? I looked at the harness wire from the key switch, and it did have a blue wire in it.
Is there a wire schmatic and maybe some voltage reading? I did ohm the pink and black wire from the sending unit and they are good.
Any help will be appricated.
