yamaha not peeing
  • yamaha not peeing
    On a 2004 150hp carb motor hooked up to flush ears will it only pee after thermostats open ?
    peeing Yamaha
    Put it in a tank. The flushing ears sometimes don't put enough water into the system to really fill the motor. high sierra
      Not peeing with lower unit flusher attached
      Replace water impeller get ordering, could just be outlet for water is plugged 2! Stick little pin in there
        high sierra is right not enough water from hose
          Thermostats do not need to open up for the tell tail to get water to it
            Thanks, all is well.
