I have a 2002 F115TXRA outboard. I severly overloaded the boat for 8+hours, full throttle, top rpm was about 3800. boat never plained. At idle the cylinders all fire properly, no misfire. bring engine to a higher rpm, 1500+ and cyl.3 is completely dead, cyl.1 50% dead, cyl. 2+4 strong. Ran compression test all within specs. Replaced spark plugs, changed oil, replaced oil in lower unit. no metal found. pulled valve cover and checked valve clearance all in specs. any sugestions please. thinking about pulling trouble codes while running the engine.
misfire above idle
what were the compression #s? I have never seen specs on compression
Leak down tests are better indicators than compression
How did you decide a cylinder was dead and half dead?
Is there good spark at problem RPM?
If compression and spark are good then check timing and if that is correct at problem RPM the you are left with fuel problem
