My new style tiller arm is set up to push when the throttle is twisted open. However on my 70 hp Yamaha the carb linkage needs to be pulled open. What is the easiest way to correct this? Do I need to take the inside gears out and flip them?
Wont matter... When i open the throttle from 0 to 100 the arm inside moves towards the motor. I need it to move towards me. My carb linkages inside where it connects need to be pulled open not pushed.
