I have a 2006 90 hp 4 stroke the trim has quit working battery shows charged and motor starts fine. you can here the trim motor click but not run. where do I look? I played with all the connections I could find under the consul that come out of the control handle. With no luck but a few minutes later when I tried the switch the motor came up but now won't go back down.
Trim & Tilt problem
Trim & Tilt
Not yet is that a seprate reservoir from the steering? My Dealer was little help and the book not much better
Originally posted by JSDarby1 View PostI have a 2006 90 hp 4 stroke the trim has quit working battery shows charged and motor starts fine. you can here the trim motor click but not run. where do I look? I played with all the connections I could find under the consul that come out of the control handle. With no luck but a few minutes later when I tried the switch the motor came up but now won't go back down.
I haven't got my boat back yet, having a mechanic do the job as i'm not to gifted with tools. but it seems like a simple job and you can probably get a new motor for around $300 - 400.
good luck
serious $800 and you think that is what is wrong lol
Things like this just do not break that easily. I bet a $20 relay is your problem
ÂÂÂÂÂÂÂ
