The varable *****ing speed can be activated with the Command Link tachometer if you have it. There is no dash panel type kit available, only Command Link Tach and Tiller handle.
You would need 6Y8-WE83S-70-00 Commqnd Link Square Tach kit
Also need main Bus wire to connect to hub at transom and to hub at console, need to measure boat to see what lebgth harness needed and also a Pigtail Bus wire to connect gauge to hub at console(need to know length needed).
Pigtail and Bus wire would probably run about 150.00.
6Y8-WE83S-70-00 CMDLK 1 GAUGE SQ KT
I can only use a round tachometer kit because I'm replacing Suzuki tachometer 3-1/4" dia and voltage gauge 1-5/8" dia..
I thought I had it figured out:
6YR-W0035-E2-00 Command link round multifuction tach kit.
Rpm, trim angle, oil pressure, over heat warning & total hrs.
I want to use the 50rpm option for *****ing but if I can't get a round version of the above will the one below work other then the 50rpm control?
6YR-W0035-E2-00 Command link round multifuction tach kit which controls
6YR-W0035-E2-00 is not Command Link, it is standard digital gauge kit. You will Command Link Gauge and the square gauge kit is best gauge set, the square CL will fit same hole as round gauges do. If you still want round CL gauge use 6Y8-WE83R-60-00 Round Command Link Tach kit, one main bus wire and one pigtail bus wire also need to install.
