2003 Yamaha 90 hp outboard
  • 2003 Yamaha 90 hp outboard
    can i change the leg on my motor to a jetleg ???
    If you have the two stroke with a 20in shaft you will need the Y90 pump from Outboard Jets - Make Every River Longer. You will also need to raise the motor about 5in, an adjustable jackplate works well for this. If you're not in a hurry, keep an eye on ebay or craigslist as the new pump assembly runs around 2k.
      90 yamaha
      Motor is a short leg four stroke
        Y100-4 Give OBjets a call, they have always been very helpful.
