My tilt has been actng strange this season. Almost acts like an air issue, will not always lift all the way out, occasionally will not go down.This is the 4th season only about 18 hrs, we don't go far.
No visible fluid leaks, o-ring is good on the plug.
Is this hydraulic fluid or automatic transmission fluid, would like to top up to see if that helps.
Thanks, Cal
Thanks, Cal
