I have a 95 Yamaha 90tlr out board motor and I need to know how many turns the air/fuel mixture screws need to be turned out from fully closed? This week is the first week the boat been in water in 10 years. Got the carbs all cleaned out and filters changed. Motor runs good but I think its using touch fuel for the distance I am going. I have the screws 3 turns out from fully closed. Is this too much? Any help would be great, or link to a factory service manual would be great seeing how I don't have one.
Need help w/ 95 yamaha 90 tlr Carb
Thanks 200090 but what do you mean for 520 degrees? So I would say that I am a lot to rich then. I am running in upstae NY. Another question on my throttle control box there is a toggle switch,underneath the throttle lever. I have no idea what it does. In owners manual it just shows it as a closed hole and says nothing about the switch. Does any one have a clue what it does or is used for?Last edited by Gone-fishin; 08-25-2011, 09:12 PM.
YAMAHA MANUAL STORE
Find the service manual # that you meed and then put that into your search engine to see what all you come up with
