Trying to figure out what is wrong....will start and run great for about 3 minutes...then drops to 2000rmps or so...no horns...coils, and plugs and wires check...seems to be #2 cylinder shuts down...fuel pump assymbly checks...thermostat checks...if you pump bulb with screw out of side of #2 carborator fuel spills thru so not clogged I don't think...if you let it sit for 30 minutes or so...will go thru same routine...start and run fine for 3 minutes or so? I have been told it could be trigger relay or stator...have ohm meeter...not sure how to check though....any other ideas? Have also been told the cdi unit assymblies don't hardly ever go bad on these...any help greatly appreciated...
ps compressions checks also...thanks
