I have a couple of 9.9HP 4 strokes. Each is fed gas through a racor filter/water separator.
I would like to install a suction gauge on the output of each filter so that I know when the filters need to be changed.
Question is:
1) What range of gauge should I use. Is 0 to 200 psi appropriate? If not, what suction pressure would I typically see from a Yamaha outboard fuel pump for a 9.9 4 stroke?
Thanks folks.
Question is:
Thanks folks.
