hello i am new here so i dont know all the rules, sorry.
i have a yamaha 40elrq 1992 and it just started overheating at idle.
i cleaned the tell tale tube and i have good flow but it gets very warm before alarm goes off.
i pulled the thermostate and checked it for correct opening temp 135-145 it seems ok.
all was clean inside as it is only used in freshwater.
i re assembled without thermostat to see if situation would be the same and it was identicle problem.
there is good stream till alarm goes off and then it deminishes.
is there a poppit valve or a pressure relief valve that needs servicing?
i cannot seem to locate it or its position.
in all this time the impeller has never been replaced and i will begin there after i figure out about the pressure control valve.
thanks in advance.
thanks in advance.
