2005 90hp tlr (81 hrs on motor)
Everything running perfect put on trailer and stored, two weeks later starts but only runs on one cylinder (the upper cylinder). Ok, I can fix this so run compression test (120 on each hole) , drain fuel from carbs and 25 gallons from tank and replace with 5 gallons of premium. Started up same problem, what the heck. Recent service include plugs, water pump,new mini 10 micron fuel filter, cleaned strainer inside of cowl, lower unit drain and fill. When it starts it doesn't miss just sounds like a one cylinder motor, like a motor that has overheated and is in limp home mode. No alarms or lights flashing. Any suggestion on solution ?
All 3 coils firing
All 3 coils firing
