i have a 200 year 200hp yamaha, the oil tank will only fill if i use standby switch, the sending unit in tank ohms out ok but will not activate reserve tank pump but as mentioned above the standby switch does, the pump in reserve tank is working and oil flowing freely from stand by switch, can you help
yamaha oil tank sensor
