Won't start.....HELP!!
  • Won't start.....HELP!!
    I have a 1991 Yamaha c55elrp. It will fire when starter fluid sprayed in carbs but won't start. Getting fuel to the carbs but not sure if I'm getting fuel to the cylinders. Does this motor have a fuel pump? Could it be clogged jets since it will fire with starter fluid? Any other suggestions as to what it could be?
    wont start
    take the carbs apart there are plugged jets or float is just stuck
      Ok got it running. Problem was water in fuel tank instead of fuel.....lol Now I got a buzzer going off and don't know why.
        replace all cooling parts then repost:
        waterpump and housing
        stats
        PRV
          Ok figured out the buzzer thing. Impellar was bad so replacing it and cleaning out passages.
