I changed the water pump, while on my bench I turned the splined shift shaft to check it's movement. Reinstalled the lower unit now stuck in forward and won't shift out of forward, shifter moves, but nothing?
F60tlrc
I find it hard to believe that you could have broken it by just changing the water pump. The shift rod should not be easy to turn. You would need a pair of pliers and a cloth to protect the splines to get it to move far enough to shift. It's not something you can do with your fingers. If you can spin it with your fingers something is wrong.
As your lining the shifting assembly up while putting the lower unit on. You got to SLIGHTLY adjust the rod with long needle nosers to ensure it's again in neutral. I do yhis with the two peices resting on one another and oncce thenprop spins freely i slide the linkage together . I have this problem everytime even w/o screwing with the linkage.
Hope this helps
