1997 200hp knocks at idle but seems to go away above 1500 rpm. Compression is 100-112. plugs seem to be a little wet. Checked water pump and pulled up on shaft and reseated to make sure it wasnt play in the shaft. Started it up with the lower unit off for a second and still heard knock. fuel pumps have only about 100hrs on them and less than 2 years old. my son did run it dry on fuel right before all this started.
97 200hp ss knocks at idle
removed plugs and turned flywheel so pistons where tdc and on the downward movement, held flywheel and pushed on piston with a wood rod. found movement in port side top cylinder and all the others had no play or movement. does this mean a bad wrist pin????? thha also happens to be the one with the lowest compresion. about 10% difference from the others
Â
