My pressure gauge at the dash has stopped working. I disconnected the hose from the motor and rain the motor flush hose. I get no water coming from the coupling on the motor so I figure the outlet coupler is clogged on the motor. But I can not figure out how to get to the hose connection. It is up under the starboard side of the block behind the shifter cable. It is a brass nipple and the water hose is connected with a spring clamp. How do
you get the nipple off to clean the outlet ?? Thanks for any help.
