Carbs dirty
  • Carbs dirty
    I have some problems with dirt from bad fuel, I would like to clean out carbs, and check to see if any additional problems, I drained most of all fuel , changed several times racors, still engine will not idle , will eventually stall, open full throttle will start , will start in nuetral run and stall. I want to clean out carbs, ? early 250 txr motors, can I download a repair manual? :Thanks
    Buy a Yamaha service manual it will do you well if you plan on working on it yourself
      DOES ANYONE NO If I can purchase it online ?
        Look up the manual # you need for your motor on the yamaha site and then punch that # into your search engine to see what all pops up
        It's not rocket science so you should be able to handle it
