I am tired of having only an idiot buzzer for water temp on my 1998 250 hp.How difficult would it be to install a temp gauge?
Temp. Gauge
Blizzard,
Not very difficult - get a Yamaha water temp kit that includes gauge and temp sensor. Sensor installs into one of the plugs that screws into the top of either cylinder assy. You can install either a temp sensor or a water pressure fitting there.
Run one wire from the temp sensor to the gauge that mounts in console - you will have to cut out a hole, of course, in your console. Run power to the gauge, and your done [img]smile.gif[/img] .
Good luck,
Ken K
Yeah I would install a temp gauge AND a water pressure gauge, since you have to make the run anyway.
You can order them online here: http://www.boatsunlimitedny.com/Yamha_Controls.htm
Or pick 'em up at the dealer for about the same price. Remember you need the sending units for each also, they're not included with the basic gauge pack.
Mike
Blizzard,
On my 2000 C115 (V-4 block), the brass plugs are located on the very top of each cylinder assembly, about an inch away from where the head makes contact. Yours should be the same. Go take a look at the parts diagram for your motor in the online parts catalog of boats.net (see above).
Ken K
ÂÂÂ
