F-150 prop selection help
  • F-150 prop selection help
    hey guys new here and would appreciate input/help.
    looking for a new prop to provide better low end bite. avg conditons here 2-4ft
    a little low on power i know but repower not an option.
    vessel is a 2007 striper 2101
    yamaha f150
    15m alum prop stock
    105 gal fuel
    50 gal bait tank
    fully loaded i'm pushing 5300lbs
    test 1 ---conducted in harbor 2-3"chop
    wind 5-7 knots
    5500 rpm 36 mph
    on plane engine trimmed up
    50 gal bait tank empty
    80 gal fuel
    approx weight 4850
    test 2 ---in harbor same conditons
    5200 rpm 33mph
    bait tank full
    80 gal fuel
    approx weight 5300
    test 3 ---outside harbor
    4600 rpm approx 22mph
    seas 2-3 ft
    bait tank full
    80 gal fuel
    not being concerned with top end speed rather low to midrange punch, was considering a solas 4 blade 13 pitch 13.5" diameter stainless prop. any thoughts or recomendations? chastise as you see fit.
    thanks for the help.
    You could use 500 more rpm at WOT. Have you tried raising the engine up a hole or 2? Most engines are set too low.
    Propping correctly & how to test props.....
    Stanley Islander 19, 2006 Yamaha F150TLRC. Ottawa, Canada
    16' York River, 1986 Yamaha PRO 50.
