Last week while going upriver, on step at about 80% throttle - the trim acted like it was stuck then released. Trimmed again same action - like it hung up. Next time the engine died. The starter motor and trim would not activate at all. Was unable to restart for about 10 minutes, then engine would turn over and start and trim worked. This happened on two occasions.
Second time, we got into shallow water, trimmed up and engine died. Drifted about 10 minutes again and then starter and trim became operable again.
Battery seems strong and shows 12-13.5 volt on gauge. Ran motor and activated trim at low rpm and higher rpm for about 20-30 minutes (while anchored at beach) with no problems.
Other threads suggest testing battery, wiring, connections, etc. I plan to do this and if no luck will take to a shop.
Does anything obvious jump out at anyone?
