engine has been running fine until this past weekend. engine will run all day smoothly at 1200 rpms. when i attempt to accelerate it has no power. if i throttle down to 12-1500 rpms it runs fine no alarms. i am thinking it may be the fuel pump but wonder why it will run fine at low rpm. any ideas? fuel is fresh, new plugs, new fuel filter
90 hp 2 stroke idles fine but boggs down when throttled up
make sure the timing is advancing as the throttle is applied, easy to do and is fairly common, and causes the problem you describe. Just remove the engine cowling (with motor not running) and have someone move the throttle while you watch the motor end, ensure the carby part moves along with the timing assy that is under the flywheel, it is connected by a linkage and is easy to see. If all that is OK, then I would be suspecting a carb rebuild is in your near future.
