I have a 1996 Yamaha 150 2 stroke on a 22' Hurricane deck boat at WOT it is only getting 4600RPM. I have a 14.5x17 Michigan 3 blade aluminum prop on it. What could be causing the low RPM's. I have it serviced every year and no statements about the motor just that there were no problems. When originally purchased this thing went like a you know what. Any suggestions?
yamaha 150 2 stroke 4600 WOT RPM need help
did you change any filters like you said?
The only Hurricane with a 150 in the performance site I found was running a smaller diameter prop and small pitch also and it was getting 5800 and 40MPH and it was a 23.2ft
http://www.yamaha-motor.com/assets/p...1118-GFY-Z.pdf
Didn't change any of the filters appeared to be fine. I tried to open that link and it came back no longer available what was the oitch and diameter of that prop they were running?
ÂÂÂÂÂÂ
