Hello, I posted about 6 weeks ago on changing the water pump on my 225. I still can't get the lower unit down. All the bolts are removed, even the one under the zinc. After hammering and prying with screw drivers it's only come about an 1/8 of an inch. A local mechanic advised me to start a few of the bolts and run the motor. I've done this and it still will not drop down.
He said the shaft is froze in the crank or a bushing is stuck. How long can I beat on this until I destroy somthing? I hope someone has a answer. I also bought the manual, but that is useless on this project.
