Using Yamaha lube, fuel additive, etc
  • Using Yamaha lube, fuel additive, etc
    I just bought a used pontoon boat to use in freshwater. It has a Yamaha 50hp 4 stroke OB. In reading the manual on-line, I see the 'suggestion' to use Yamalube oil, Ring Free Fuel Additive and Yamaha Fuel Conditioner and Stabilizer.
    How important is it to use the Yamaha "recommended" products -vs- other brand products.?
    What brand oil can I use (dino or synthetic) ?
    Should I use the Ring Free Fuel additive when using 87 octane brand name gas with 10% ethanol.?
    Can I use Sta-Bil Marine additive in lieu of Yamaha fuel stabilizer?
    Thanks in advance
    Bob
    I'd recommend using the Yamaha Ringfree at the "preventive dosage" and the Stabil all the time, and install a fuel/water separator type filter. You should be pretty much "home free" regarding fuel related problems. Good Luck!
      Good suggestion re a fuel/water separator type filter. Yamaha makes spin-on cartridge filters as do many other sources. Do most OB users (50hp 4-stroke) use the replaceable cartridge or the type where you can drain the water to extend the cartridge? As I will use E10 this makes sense.
        I installed a Walmart/Attwood fuel/water separator($27) on my transom several years ago, easy 2 screw installation, works like a charm removing water, trash, debris, whatever. New cartridge is $8, but I use mine for a long time, just unscrew it, dump out the trash, screw it back on, good to go. You still have your motor-mounted filter screen as back-up, in case anything managed to slip past your big filter. Yamaha and Racor make some great filters, but they cost a good bit more, and for my purposes the Walmart unit works fine. I finally replaced my cartridge after about 3 years, and cut the old one open with a hacksaw, wasn't really much of anything in it. Looks just like a pleated paper oil filter element. Good Luck!
          So, from the few comments, and from further google searches including the Yamaha Web site, it seems that any quality 4-stroke/water cooled OB oil will be acceptable:" Yamaha recommends Yamalube, of course, but if you simply cannot find it, choose oil that specifically displays the FC-W® rating logo."
          Sta-Bil fuel additive should be as good as Yamaha's conditioner/stabilizer (and less expensive and easier to find in the store).
          And Yamaha's Ring Free Fuel Additive is okay for 4-stroke engines but is primarily used for 2-stroke engines which have more carbon build-up. So, use it if I like, use it occasionally, or don't really need to use it - maybe option 2 is best 'use it occasionally'.
          The suggestion to install a fuel/water separator is a good idea if the engine does not already have one (especially with E10 fuel) <<and going to E15 soon per Obama's edict>>. Yamaha says all newer engines are made to run on E10 but *NOT* anything higher!!
          I was just interested in what long time Yamaha owners use in their OBs - do you stick with Yamaha brand products faithfully, or do you use any premium FC-W oil
            I used Yamalube for years with no problems but switched to Pennszoil 100% Synthetic Outboard Oil a few years ago, and it seems to smoke less, burn cleaner, less carbon. I tend to keep my motors for many years, so preventive maintenance is important to me. Good Luck!
              I used Yamalube for years with no problems but switched to Pennszoil 100% Synthetic Outboard Oil a few years ago, and it seems to smoke less, burn cleaner, less carbon, but more expensive. With the fuel additives, fuel/water separators and just good preventive maintenance, these motors run really well, and dependably! Good Luck!
