I have a F115 that will not start. The ECU is not grounding the fuel pump connection. The fuel pump works when wired straight to 12vdc. Motor will start if pump is running.
According to the manual, there should be two electrical connections to hook up a test light to review codes. I can only find the blue/white wire. The red/black does not appear to be there. There is a red/black in the test socket but I can't figure out how to see if there are any trouble codes.
Any help would be appreciated. Thanks!
