Wiring harness question
  • Wiring harness question
    I have a 2008 Yamaha 60 Tiller model. I pulled the connector from the tiller to engine and found I had a corroded pin on the tiller side of the plug. Is it possible to buy a new plug?
    Has anyone taken apart the connector and independently connected each wire?
    Does anyone have a wiring diagram for the main harness for the '08 F60 TLR?
    I was contemplating just butt-splicing all the connections,(as new wiring harness is $700.00) but I found that the colors do match on each side of the connector. Can I just line up the pins and splice accordingly. Just want to be cautious and ask, since the colors are all different on each side of the plug.
    Thanks for any insight.
    The only way to get the connector is to get the harness.
    Haven't tried to splice wires but should be able to match wires up.
