2004 F150 4 Stroke Stalling
  • 2004 F150 4 Stroke Stalling
    I know there have been some posts on this before however, are there any new fixes to this problem.?? Or an old fix that I missed?
    Engine has the vapor lock mod, Brand new VST, sync and link, fuel filter, vaccum check, all set. It is a low rpm stall when shifting such as when you are docking ect.
    Anyone got an answer to this ?? Thank you so much. !!!!!!!!!!!!
    Very grateful if anyone would share.
    easy fix.
    do you have access to a laptop with version 1.33?
      Thanks rodbolt, personally no but I'm sure my tech can get his hands on one. What shall I have him do? Would love to fix this issue. Very much appreciate your knowledge and input.
        then make sure the shutter pairs are synchronized,then we are going to open the shutters with the adjustment screw then we are going to reset the TPS to .70-.72V.
        when its all said and done your looking at an ISC command in the 40-47% range with a TPS voltage of .7-.72V and an engine idle speed of about 700 RPM.
