I can't get my trim-tilt working since I foolishly opened the fill port with the unit under pressure. I've tried opening the man. relief valve, top off the reservoir, manually let the motor down then raise it again several times manually while topping the tank off at the top each cycle. Now, do i try to raise the engine with the motor while it is in the down position or should I try to recycle it while it is up and on the stops? Any help would be appreciated. Please walk me through it.
Bob
Bob
