I tested mine by running the engine up to operating temp. The boat should really be in the water for this test. Once the engine is up to temp. Check the output voltage of the sensor. You should see a voltage range of roughly .35-.7 volts. And it should fluctuate back and fourth rapidly if working correctly. They also say to cover up the hole in the #1 throttle blade ( richen it up) and see if the reading changes. The shop manual will show which harness to measure for output voltage.
Good Luck
Mike
Good Luck
Mike
