Ok question on the timing. On the fly wheel their are 4 tdc marks tdc1 tdc2 tdc3 and 4 question is in the manuel says to have the mark lined up with tdc1 at 5 + 1 deg ( at Idal) on my eng it is at tdc2 at 5 + 1 deg. Is this right or even ok.
1986 yam 115 v 4 timming marks
when the upper stbd(#1) piston is at TDC then the TDC marks with the BTDC and ATDC scale should be at TDC.
idle timing should be at 5* ATDC,carb pickup timing should be 4* ATDC and wot timing should be at 25* BTDC.
note the difference of ATDC and BTDC.
if the scale does not line up with the physical piston location ethier the pointer is off or the flywheel key is sheared.
Â
