I have no fire to the coils. I checked the bus bar that feeds each coil with a 12 volt tester, it had no power any where on the bar. I then checked the control unit located just below the bus bar it has a yellow, cream, brown and black wire all going to the bus bar and a pink wire coming from the wire harness, none of them have power. I thought of running a jumper to the pink wire thinking that it should be the power feed but I was afraid I might fry something. Any help you can give I'm about to pull out what little hair I have left?
Yamaha 175 hp Ignition Trouble
Did you check the emergency stop to be sure the lanyard is in place.1999 Grady Sailfish SX225 OX66
over the years there has been something like 11 versions of the 175 HP yamaha.
without a model number any and all advice is simply garbage at best and seriously incorrect at worst.
ÂÂÂÂÂÂÂÂ
