I accidentally engaged starter, very briefly, while engine was running. immediately lost all power -- no radio, no GPS, no hydraulics.
checked fuses in console, lost one 5 amp, replaced it. could have already been gone, though.
removed engine cover -- starter was engaged with flywheel, I disengaged it easily. checked fuses in engine fuse box, all intact.
must be some sort of breaker or reset to protect the starter; I can't find it and manual mentions nothing.
My 22 ft Pathfinder CC also has a battery switch, although it does not appear to cut off power to anything. It has two fuses and they are both fine. I switched it off and on and I also engaged and disengaged the dead man switch for the ignition in case it had a reset feature.
any ideas? can't imagine that this is a complex fix.
Will
Will
