winterizing 2007 f115
  • winterizing 2007 f115
    i have a 2007 f115 yamaha and would like to know what would be best to do to the engine for long term storage,let's say for about 2 years.
    for two years?
    remove the air box.
    add crankcase stor-n-start to the engine.
    start engine and fog it well with fogging oil.
    shut engine down.
    remove the VST and fuel rail assy.
    remove the injectors and drain the rail,dissasemble and clean the VST.
    use low pressure air to clear any fuel from the fuel pump and fuel lines.
    drain the fuel filter.
    spray the inside of the rail and VST with fogging oil.
    even with stabil a two year storage with fuel in the lines VST or rail will cause issues.
