Tach question
  • Tach question
    I have a 2005 Ranger 169 Ghoast with a 2005 yamaha 90 2-stroke. The gas gauge was not working so I took it out to test it. I mistakingly shorted out the gauge when I put it back and now none of my gauges work including my systems check tach. Also, the engine warning alarm sounds when I turn the key on. The engine runs fine, so do I need to replace the tach to get the alarm to stop? Is there a fuse between the ignition switch and the gauges that might need to be changed? Please help!!!!!
