I am re rigging a 2001 250 yamaha v max on to a old 24 talon and putting in a new lavorsi gauge cluster cant seem to find a "good" wiring diagram for this engine
?? I'm Trying to hook up a Tach which i believe is the solid green wire coming from the flat 4 pin connector from the engine? or is it the solid green wire from the key switch harness?
Then im trying to hook up a water temp gauge and i know that that the wire from the temp sender to the ecu/ecm is black with yellow but is there a wire coming out of the ecu for this or do i need to put a another sender in the blank plug on the i believe the starb. side of the engine and run a wire to the dash?
The flat 4 pin at the helm from the engine has a solid green? tach?
greenw/ red? Red oil warning light ground through SW3 in main tank oil
sensor to tachometer found this here Wiring Color Codes for YAMAHA Outboard Motors.
and a white with brown tracer?
and Black ground???
Any help would be great thanks!
a call would be even better will be up about 8 am eastern time 573-286-5993
or email rileymarineservices@yahoo.com
and Black ground???
