f60hp waterpump
  • f60hp waterpump
    getting ready to change the water pump for the first time on my 2006 f60 yamaha 4 stroke. Before I start can any one tell me what it takes to remove the shifter shaft. Some motors you need to do nothing other the shaft needs to be unscrewed. On this motor I don't see anywhere to unscrew. Please help.
    Thanks Alleycat
    Thanks Alleycat
    I imagine my t50 is similar. If it is you don't need to do anything. I know what u mean, coming from a Johnson you had to pull the grenade pin up top for the linkage to slip down the leg.
    Good luck
