200 TJRP Oil Level Sensor and Oil Transfer Pump
  • 200 TJRP Oil Level Sensor and Oil Transfer Pump
    Hi, I have a 1991 200 TJRP that has a Prop lower unit now, not a jet. It has run flawlessly for the last 4 years. This winter, laid it up as usual. But transfer pump not getting signal to start. Oil will pump when manual transfer switch is thrown. But not when the motor mounted tank switch is moved. It does alarm, but does not trigger the oil pump to run... Any Ideas? The red's are running,and I need to go get me some Salmon in the freezer!!!!
    Thanks in Advance,!!!
    here you go.....
      Thanks all, since my outboard is a 1991, I found out that the Trim-Switch that had frozen-up over the winter had been the problem. It was stuck in the "Up" position, so it was stopping the signal from filling the engine mounted tank. This is the set-up for 1990-1995. Thanks to all the other posts here that helped me figure this out!!
      Garry in Kodiak, AK
