Decarb Procedure
  • Decarb Procedure
    There are numerous posts that mention decarb of engineIs there a way to decarb an engine when the engine is not running? Would like to attempt to free a stuck ring on a cly before sinking a lot of money into an electrical problem.
    re-post
    I know that most of you think I am quite dumb, and you probably are correct. So I assume that the answer to the above post is no way to decaurb a non running engine. thanks anyway. so long
      decarb
      try pulling plugs, hand turn fly wheel and spray into spark plug holes with engine tuner cheers paul.
        change spark plugs
        Last year I bought a new 4 stroke 115hp. I can't figure out how to remove/change the spark plugs. In fact, I can't even find them, unless they are the four orange gizmos on the port side with wires attached to them. Why would there be wires attached to the spark plugs? Any help? Thanks.
