Trying to chase down a couple issues......
Here is what has been done for Spring maintenance:
- Replaced main fuel filter, VST filter, canister filter after VST tank.
- New plugs, 10 micron Yamaha fuel/water separator element.
- New LP pumps, cleaned O2 sensor
- Compression #'s within spec/even across cylinders (slightly lower in bottom 2 which I have read is normal).
Had Yamaha tech check HP pump (680 psi) and pump in VST tank (50 psi). Pressures remain steady at speed all the way up to WOT. All cylinders fire in gear and spark has been verified. Engine idles low when started (500 rpm) and runs rough idling through the harbor..... seems sluggish overall. Idle rises to 1300 after cruising for a while.
The engine is on a 20 Mako (1993) and I am using a Yamaha 15.25x15M Saltwater Series prop. Should be turning about 5500 rpm WOT.
Not sure what to check next...... any help would be appreciated. Thanks.
