Just reinstalled the injectors and replaced the injector driver. Started right up..... idles fine and additional 2 cylinders engage when put in gear. Just need to test it out in the water.....
One question regarding the injector o-rings and the fuel rail. I forgot to lube the o-rings when re-assembling..... everything went together fine and I checked for leaks while the engine was running. Everything appears fine, but I feel stupid that I forgot to lubricate the o-rings. Should I leave it alone, or pull the fuel rails, check the o-rings, lube, and re-assemble?
After installing the injectors in the head, I evenly tightened the fuel rail bolts to seat the injectors to the rail. It went smoothly, but I would like to know if this could cause an issue.
