Gents,
Following procedure in manual, timing set by Yam tech in York Town where I bought the boat. Got 2-new red marks on the adjusters and not messing with it. The rb nailed it when he said I had bad fuel and I had to take off carbs and clean. Syncing carbs and the book says to adjust throttle lever adjusting screws on the top & bottom carbs. Simple, loosen cw and that syncs them to the middle carb. After that adjust the pilot screws: Stb side 1-1/8 turns, port side 5/8 turns, the Yami tech had them all out 3/4 turns. Please confirm 5/8 & 1-1/8 turns is correct. Little confused after that regarding adjusting throttle roller adjusting screw on the middle carb. Shouldn't that be set to fully close throttle plates? So I start with a fully closed throttle and open to adjust idle with the idle adjusting screw. Can't help thinking that I'm making too much of this but I don't want to screw it up. Thanks Guys!
