i am working on a 2001 150 2-stroke for a customer. Engine tank was empty and pump not filling up tank. pump is not running and alarm was sounding. no power to pump, also emergency switch does not activate pump. i can hook up 12 volts to pump wires and it works. gut feeling tells me its the CDI unit. i just want some suggestions before he spends 800.00 on new CDI.
oil problems
then find out why.
but the 12V power on the brown wire does NOT come from the ECU.
there is a splice in the 10 pin main about 4 inchs behind the engine connector that can fail.
its where the brown lead is spliced to the yellow key on 12V power wire.
the ECU simply controls the ground path for the pump.
Originally posted by kracker1972 View PostI DO have power at switch on yellow wire. Meter connection was loose, i pulled back insulation on key side of 10 pin connection and i have no power there. Bad harness??
now that you have the meter leads fixed, check the voltage on the brown wire at the remote tank to a good engine ground with key on engine off.
brown will splice into the engine main harness yellow a few inches behind the 10 pin main connector.
