I replaced a definitely faulty fuel pump on my '02 Yamaha 90tlra. On a test run it started, idled and ran at all speeds perfectly for several minutes. I throttled down, then upon throttling back up the motor would not pass 2000 rpms. It still starts, idles, and runs perfectly up to 2000rpms but will not go any faster. I'm stumped. The igintion and fuels systems are fine. The water pump is brand new. Mike
stuck at 2000rpms
Originally posted by MikeFaircloth View PostI thought about the temperature sensor when I discovered that the water pump was not circulating properly. I replaced the water pump but the motor still will not exceed 2,000rpms. Could the sensor be stuck? What other sensors should I check? Mike
