Hello,
Do you know what is "Shift Position Switch" on a F115 ?
I have done diags and I have this error code 28:
Diagnosis,
,Code,Item,Result,Condition,
,28,Shift position switch,Irregular,Irregular signal,
,13,Pulser coil,Normal,,
,15,Water temp sensor,Normal,,
,18,Throttle position sensor,Normal,,
,19,Battery voltage,Normal,,
,23,Intake temp sensor,Normal,,
,29,Intake press sensor,Normal,,
,37,Intake air passage,Normal,,
,44,Engine stop lanyard switch,Off,,
Engine Monitor,
,Monitor Item,Result,Unit,
,Engine speed,904,r/min,
,Intake pressure,555.9,HPa,
,Intake pressure,16.69,inHg,
,Atmospheric pressure,1005.5,HPa,
,Atmospheric pressure,29.8,inHg,
,Ignition timing,ATDC 3,deg,
,Battery voltage (12-16),14.90,V,
,Throttle valve opening (0-90),0.8,deg,
,ISC valve opening (0-100),77,%,
,Fuel injection duration,2.43,ms,
,Water temperature (below 90),48.7,°C,
,Water temperature (below 194),119.6,°F,
,Intake temperature (below 70),26.7,°C,
,Intake temperature (below 158),80.1,°F,
,Oil pressure switch,OFF,,
,Engine stop lanyard switch,OFF,,
,Shift position switch,OFF,,
,Dual engine system switch,OFF,,
"code 28":
Many thanks for your help
Diagnosis,
Engine Monitor,
"code 28":
