MTCFISH,
Raise the outboard all the way up with the power t/t and drop the locking lever down to secure it.
There is a filler cap on the fluid reservoir of the power t/t - remove it and add t/t fluid up to the bottom of the filler neck - you can use Dexron 2 ATF. It's kinda hard to pour directly into the hole - use a long skinny funnel or use tubing and let the fluid siphon out of can into the filler hole.
Good luck,
Ken K
