1996 Yamaha C40PLRU Fuel Problems
  • 1996 Yamaha C40PLRU Fuel Problems
    Bought boat with this motor on it last winter. It runs fine and reaches WOT but almost every time I shut the motor off I have to pump the fuel bubble until it is rock hard to get it to open up again. If I start it back without pumping the bubble it will start but when I put it in gear and try to accelerate the fuel level in the fuel filter drops and the motor dies. If I pump the bubble up each time it runs perfect, I can slow down to idle and then accelerate again with no trouble but if I shut the motor off I have to pump the bubble up again.
    Any ideas??
    PS - I have changed all fuel lines, fuel bubble twice, cleaned carbs twice, new fuel tank, cleaned screen in fuel filter, new fuel pump(not rebuild), all fuel fittings are new.
    If you are tilting engine up when shut off then may have to reprime before starting, check compression, Resync and adjust carbs. Check fuel pump.
