Originally posted by rodbolt17
View Post
Yes, I realize the procedure I posted was for a completely torn down engine. The point I was trying to get across is that they still don't tell you to set the engine at TDC when reinstalling the counter balancer.
So if the keyway F is the triangle why don't they line it up with the casting tab in the block?
Ok so this is the engine at TDC,
This is the engine in alignment for installation of the counter balancer, note the location of the casting tab, the key is aligned with the MACHINED SURFACE of the cylinder block and crank case cover!
Think about it, if this engine needed to be at TDC for a counter balancer replacement wouldn't the tech bulletin tell you to set the engine at TDC? Instead they tell you to make sure 20* btdc mark is centered on the bendix!
I hate to say it but you have been doing it wrong since 2006! In my line of work I usually don't get a second chance, its gotta be right the first time!
